[SOLVED] Wifi adapter not working after restart ?
Sep 25, 2021
23
Hey guys so my earphones weren't detected for some reason so I restarted my laptop after which my wifi adapter stopped working and now there's a "Windows is setting up the class configuration for this device(code 56) and other errors I'm facing, pics below.
Also facing 2 consistent error after restart in event viewer
The rasman depends something,
The inpoutx64 access denied.
Tried Uninstalling device then restart, Uninstalling device and installing oem drivers again, reset button in network settings of windows, nothing worked.
Also tried Linux and it is working fine there.
View: https://imgur.com/a/QIjkR2h
- Make a restore point then scan your pc with sfc /scannow , follow the guide and if you find probles which cannot be solved use DISM tool , if you find problems unfixable restart and try again until everything is fixed https://www.howtogeek.com/222532/ho...-system-files-with-the-sfc-and-dism-commands/
-Uninstall third party VPN clients. Restart
- Try windows built in internet/wifi troubleshooter, google for more info
-Try uninstalling the Wifi from "device manager" then restart pc. Let it install again, restart if needed in between.
- close laptop, take off power cable and remove main battery, press powr button continuously for 30second, put the main battery and power cable back and boot.
Reactions: XPooka
hey, thank you for the reply and yes uninstalling the vpn adapters fixed the issue!
