Question WiFi card randomly stops working ?
Jul 25, 2022
I recently bought an EDUP EP-9655GS PCi WiFi card, and it seems to randomly stop receiving the internet while still being connected. A quick disconnect and reconnect is all it needs to work again but i find it tedious while simultaneously flying a mini in Rust. I've come to see if anyone could shine some light on a fix since I'm not quite educated in this field.
did you install the driver from the manufacturer yet?
might be a problematic wifi signal from the router
windows
firewall
antivirus
other 3rd party software
update bios and chipset drivers for your motherboard
change channels of the wifi
change the position of the antenna
update the router´s firmware
change from 5GHz to 2.4GHz
