Question Wifi connection fast on mobile, but slow on PC.
lyingfire
35
I've made sure its not just my pc and phone. I've tested other devices and for some reason on any mobile device my download speed is 400+ mbps, however on any pc ive tested on its anywhere from 5-30mbps. Ive restarted my router, made sure its on 5ghz, updated drivers. I even bought a new wifi adapter.
This whole situation is very frustrating and is hurting my brain so any input would be really appreciated
Three other suggestions:
1) Ensure that only one network adapter is enabled. Not both wired and wireless at the same time. Nor two network adapters of the same type at the same time.
2) Disable IPv6.
3) Run "ipconfig /all" (without quotes) via the Command Prompt. You should be able to copy and paste the results herein without needing to retype it all.
