[SOLVED] Will a GTX 1050 TI be compatible with my system?
s6lid
22
I'm buying a psu and a gpu soon and I would just like to know if a GTX 1050 Ti would be compatible with my specs.
My specs are :
Motherboard : MSI FM2-A55M-E33
CPU : AMD A8-5600K
GPU : Integrated AMD Radeon 7560D. It's the one that came with the motherboard (I think)
PSU : Powerlogic ATX-700-W. It's a PSU that's made in china so I guess it's a generic PSU (I'll replace this before getting a 1050 ti)
RAM : 12 GB of ram
Here are more information about my specs
A Mini-ATX form factor with 32Gb maximum memory, compatible with AMD processors with the Socket FM2+ socket. Yes it is totally compatible with 1050 Ti.
Actually 10 series - 1060, 1070, 1080 and 20 series - 2070, 2080....are the best options for you. These will perform very well with your configuration.
