Compability issue, may cause the CPU not detected properly. Check using another FM2/2+ CPU if it's possibly. Try update BIOS when they can boot with another CPU.Is something wrong? Like everything is brandnew except for the gt220. This gt220 works on my 2008 ecs mobo
Have you make sure the BIOS is updated ? There is some BIOS update for 860K. Refer to manufacturer site :im using a asus a68hm-k and 8gb ram, 860k for the cpu and for the gou i use nvidia gt220 and still no display
I dont have anyCompability issue, may cause the CPU not detected properly. Check using another FM2/2+ CPU if it's possibly. Try update BIOS when they can boot with another CPU.
can i update if thats the only unit i have? And its not workingHave you make sure the BIOS is updated ? There is some BIOS update for 860K. Refer to manufacturer site :
||ASUS USA
www.asus.com
No, you need another CPU, if the 860K still not detected. Maybe a local shop may help you to update the BIOS for you.How
