[SOLVED] Will NZXT Kraken x52 cpu cooler fit in my Case? (top mount)
Sep 12, 2020
Hi,
My question is: can I fit the NXZT Kraken x52 cpu cooler, into a CORSAIR Carbide Series SPEC-DELTA RGB case ON THE TOP SIDE?
The Case says it can house a 240mm cooler on the top, but I am unsure if it can fit.
(I way playing around with the PC Building Simulator, and in that, I could not fit the cooler on the top, it was colliding with the Motherboard: GIGABYTE X570 AORUS ELITE, and the RAM: 2xG.SKILL Trident Z 8gb DDR4)
I saw pictures of the case with a Corsair liquid cooler mounted on the top,
but also I saw the NZXT Kraken Compatibility Guide Sheet: https://www.nzxt.com/uploads/download/attachment/70/Kraken-Series-Compatibility-Guide-4.18.2017.pdf
And the Corsair Carbide series doesnt fit any fans on the top (it didnt specifically mention the SPEC-DELTA model)
All help is greatly appreciated!
Well, Corsair shows a 240mm top mounted in the marketing images, so possible. Not sure about that exact cooler, obviously they used a Corsair model.
Motherboard interference is certainly a concern due to memory and VRMs.
