Sep 26, 2019
First time building a pc , please help. these are my parts:
Motherboard : MSI Z390-A PRO motherboard LGA 1151 (Socket H4) ATX Intel Z390
Cpu : Intel i5-9600K processor
SSD: ADATA SX8200 Pro, 256 GB SSD
RAM : Corsair 8 GB DDR4-3000
Pozer supply : VS Series™ VS450 — 450 Watt 80 PLUS®
Graphics card : MSI GeForce GTX 1660 Ti VENTUS XS 6G OC
Case : Corsair CC-9011023-WWCORSAIR Carbide 200R Compact ATX Case
also do i need a fan for the cpu if i have the 2 case fans working?
Thanks you for all the help
The PSU does not match the system.
+1
___
Get something good quality 550watts so you have some room to upgrade if you want. If having no idea give a budget and we'll look. You are U.S. based or ... ?
Depending on the budget, I'd go with a m.2 SSD, not SATA, and yes, a CPU cooler.
That ssd is a M.2 NVME ssd,but if the only thing for storage does it not have much room. And a decent cpu cooler definitely. Something like the Cooler Master Hyper 212 Black is already a good cooler and pretty easy to install.
Agree on the change to the PSU to a Gold rated and 550w if possible and I would definitely go for 16GB RAM with 2 x 8GB modules DDR 4 3000 or even better 3200. Ram is very cheap at the moment. Oh and a Hyper 212 would be more than well worth it for CPU cooling.
