Will these parts match?
G
Guest
Guest
PSU - Chieftec CFT-750-14CS 750W
CPU - AMD Athlon II X4 630 2.8GHz SAM3 BOX/95W ADX630WFGIBOX AMD
RAM - A-Data DDR3 PC10600 1333MHz 2GB CL9
HDD - Western Digital Caviar WD3200AAJS 320GB 7200rpm 8MB NCQ SATA 3Gb/s
MB - M4A785TD-V EVO
I think they match.
That will be a good setup do you have a GPU picked out yet? Also that PSU I never heard of it before so I dont know how good it is but depending on what you are gonna be running as a GPU a Quality 550 watt PSU is more then enough to run just about any single GPU.
im on a realy tight budget and i will be using the inergrated GPU at first later i am going to buy a ATI Radeon 5xxx something.How many watts would i need?
I would buy DD2 but the motherboard does not support it.
Il get a high quality. 550W PSU
Latest posts
