Will this Cooler block anything on my MOBO?
DeltaRecon2552
226
Will this cooler block my RAM or anyhting on an ASUS Maximus Hero VI LGA1150 board?
Phanteks PH-TC14PE CPU Cooler
I have a full ATX Case if that makes a difference.
you welcome :) well best answer is for you to decide, whoever you think helped you the most
Yes it will, it's a monstrosity, it will hover your RAM blocks, but it will not affect anything, however if you do have to change RAM at some point you'll have to take off your cooler
don't worry about the LP, Vengeance are great RAM's, and the RAM will fit fine, as i said, it'll just hover over them, not touch them
