Will this cooler keep my CPU at a safe temperature
1150 uses the same spacing as the other lga 11xx sockets.
Better question is what case and ram do you have?
It's important to know!
You're kinda all over the place with linking a low profile cooler(93mm tall) and a taller 158mm cooler
TheUnknownPC
596
Rulee09
48
Yes everything is compatible if you used the Noctua NH-U12S.
http://www.ncixus.com/products/?sku=82801&vpn=NH%2DU12S&manufacture=Others&promoid=1285
Which I think is a better choice of the two coolers you've linked.
It also plays nice with tall ram,so no worries if you ever add more.
I have a D14 cooling my 4770k.
http://www.ncixus.com/products/?sku=47090&vpn=NH%2DD14&manufacture=Noctua&promoid=1285
It would work with your gear too.
