i have an i7-3770k, so everything should work fine? thank you!Yes it would. However whatever CPU you are using in that board may hold back a 2070 a bit in the latest CPU heavy games. An overclocked i7 2600k or 3770k should do pretty well, a 2nd or 3rd gen i5 less so.
Also it says on the system requirements that i need a "6-pins + 8-pins PCI Express" idk what that means could you clarify for me?Yes it would. However whatever CPU you are using in that board may hold back a 2070 a bit in the latest CPU heavy games. An overclocked i7 2600k or 3770k should do pretty well, a 2nd or 3rd gen i5 less so.
Silver Power sp-ss850, thanks for the clarification regarding the 6+8pin thing, you explained it better than the customer support guy that just made me more confused lol 😀Yes it should pair pretty well with a 3770k.
The GPU requires 6 and 8pin PCIE power cables from your power supply. The image below shows a 6+2pin pcie power cable this can be used as a 6 or 8pin cable to power your GPU. Post the make and model of your power supply and I will let you know if it will support a 2070.
