[SOLVED] Will This GTX 1050Ti dual fan model fit in HP Compaq Elite 8200 CMT PC (Convertible Minitower)
The card should drop in. I'd advise that you check and see that the motherboard is on the latest BIOS version. What PSU are you working with?
You're advised to have at least a 350W reliably built PSU to drive your entire system with a GTX1050Ti in said system. You asked if the card will fit in the case, to that, the answer is yes. If we're to look deeper, a very old PSU that's been in service with a sticker advertising 320W will not output that amount after all these years(of use).
