Hello,
I had a problem with lCD cable in my laptop Lenovo g510, it was blinking so bad so I had to replace it, which was successful but it came at a price.
The tiny pin of the connector that fixes the keyboard cable was broken, I tried to fix it with a tape but only some buttons type and when I try something else only other buttons type or none at all.
After I logged in, I found that there is no wireless connection, as if I don't even have one! I checked the wireless adapter and the two cables but they were attached properly!
Any help would be greatly appreciated! (I know I can use an external keyboard)
P.S. The cause of the main problem is that the left hinge is not connected to the broken bottom housing anymore. So when I open or close the lid, the left hinge (with Kensington lock) remains the same, and it presses everything on its way, and that damaged the lCD cable.
Thanks in advance
Thanks in advance
