I'm trying to setup a wireless bridge between two homes that are about 170ft apart. I had one, and bought a second Asus RT-AC66U router and am trying to figure this out. I have direct line of sight between the houses except my primary router has to go through one wall (I can probably increase the distance 10ft and put it in a window instead). I was able to get a 2.4GHZ connection on my phone by standing next to a window in the house #2 but it wasn't very fast. I was hoping to get an AC bridge between the houses but now I'm not sure the signal will reach that far (on my phone 5GHz drops out in house #2).
I'm playing around with the two Asus routers just 20ft apart right now to see how bridging works. First I tried media bridge mode bud realized that I don't want that because then the secondary router can't have any wireless devices connect. Then I tried playing with the bridge settings and couldn't get it to work at all. I finally realized that having my encryption set to WPA2 was likely the problem because the feature only supports a WEP connection. This came as a huge surprise and now I think I've made a mistake in my hardware choice. After a little googling it seems like most routers only support bridging with WEP.
I'm wondering what you guys think I should do. Is there a better hardware solution that won't break the bank? Should I buy an outdoor and/or directional antenna? Will there eventually be Asus support for WPA bridging? Will the RT-AC68U offer a significant enough range improvement that I should consider returning these and getting those?
It seems like the media bridge mode might still be cool with WPA2. What if I use that then add an old N router as an access point to the secondary RT-AC66U?
Just so you know, I run a home-based business and I'm going to move some of that business into the other house. I really want a fast, secure connection to share resources and sync data. I really want everything to act like it's on the same network, plus be able to offer a guest network where users will not have access to all my network resources. I figured my hardware choice would do all this but I'm venturing out of my field here.
Thanks for your help!
