[SOLVED] Wireless mouse battery drains in less than a week
zach_
Commendable
Apr 29, 2020
7
The mouse is the "Natec Robin" model.This situation kept getting worse and worse with the time.Last time (this week) i used a brand new toshiba battery,only to find out that this little mouse drained it all in 4 days of little use,with turning it off regularly and even sometimes pulling the battery out completely.But it still managed to consume it all.I noticed a little rust at the "-" spring of the battery socket but i doubt it was there from the beginning since i bought this mouse this winter.
Any ideas?
Thanks
Very carefully clean out the "little rust" as best you can.
Use a wooden toothpick or some hard piece of plastic - e.g., tine on an plastic fork.
Goal is to ensure that there is no rust path between the "-" spring and any other conductor. Hopefully the existing rust will just flake away.
Try to find some other batteries to use and test with.
And, if possible, add a couple of photographs.
http://www.tomshardware.com/answers/id-2173703/post-images-tomshardware-guide.html
There may be other suggestions thereafter.
