Question Wireless mouse not working proprelly.
Oct 14, 2019
61
Wireless mouse keeps freezing. (The laser turns off at random times) Went to the store i bought it like 1 week ago and when they checked it on their computer it worked perfectly... Im 100% sure its charged. Do you guys have any ideas?
Mtop
Proper
Nov 21, 2019
168
14
115
Where is your wireless reciever, in front usb or back?
and how far away are you? Try to get closer - what happens?
It should be in front and not too far away.
What frequency is the wireless and are there other devices around with the same frequency?
Nothing in the way to bounce / scramble signal?
Oct 14, 2019
61
Its in the front. Distance is about 1 meeter. I have a router next to it. Its 2.4 ghz
Mtop
Proper
Nov 21, 2019
168
14
115
Is the router connected by wire or WiFi.
Try moving the router as far away as possible perferably on the other side ( put the case between router and you, see what happens.)
