I am looking for a Wireless Mouse that will work well on the couch. I mean simply just moving it around on the couch cushions and not on any sort of pad. Would the Razer DeathAdder V2 Pro work well for this or would some other type be better?
It’s never going to be accurate, for consistency the optical sensor needs a consistent distance between the sensor and the surface. There are options. When using a laptop on the sofa (including gaming) I use a table similar to this...Use for First Person Shooters. Are there really no mice that would fit this need. Would it make a difference if the couch cushions were totally smooth?
Use for First Person Shooters. Are there really no mice that would fit this need. Would it make a difference if the couch cushions were totally smooth?What are you doing on the pc? For example, if gaming then you need a flat surface for accuracy and fast movements. If just browsing or not needing high accuracy and fast movements then I’d look at a trackball mouse, it might take a little getting used to but would be better than a mouse on an uneven surface. Ultimately traditional mice are designed to work on a flat smooth surface and while you can use them on other surfaces it’s going to be a compromise and expect some unpredictable behaviour.
It’s never going to be accurate, for consistency the optical sensor needs a consistent distance between the sensor and the surface. There are options. When using a laptop on the sofa (including gaming) I use a table similar to this. https://www.amazon.co.uk/Portable-N...7-4911-9ef7-723e018c4453&tag=lionshomeospu-21Use for First Person Shooters. Are there really no mice that would fit this need. Would it make a difference if the couch cushions were totally smooth?
