Question Wlan adapter and USB port glitching.. What do I do?
hosa
34
Hello there;
I have two problems with my laptop that happened around the same time..
First is the Wlan adapter, It used to work for a limited amount of time until it stopped working,
and then I would restart my PC and it would work again.. But then it stopped working at all anymore.
There is a yellow exclamation mark on it in the Device Manager..
I tried reinstalling the drivers and making another Windows account and safe mode, but still doesn't work..
Secondly, one of my USB ports isn't working anymore, when i stick a device in it, Windows tells me "device not recognized"
and it also doesn't work after doing the procedures that i had tried with the Wlan..
Sadly i did not find any restore points on my PC, and I'd really hate to Refresh/Reset my PC obviously..
There are some IMPORTANT key points I need to mention, The two problems happened basically at around the same time.
At that time my PC was getting hot, Windows froze frequently, and i had gotten a BSOD..
Then I sent it to the technician and it was SO DUSTY..
unfortunately he could'nt fix the issues but we determined it isnt a hardware issue because they worked under UBUNTU.
I am now desperately looking for solutions, is there any kind of tool that can perform diagnostics or attempt to reset or fix these
components somehow?
I didn't perform a CHCKDSK because i kind of doubt it will fix the issue, but I need to hear a more expert opinion regarding that..
Thank you , I will be following this thread closely..
Make and model laptop?
Full system hardware specs and OS information?
What device has the yellow exclamation point?
Any error codes, warnings, or informational events in Reliability History/Monitor and Event Viewer?
Also look in Update History for any failed or problem updates.
Windows 8.1 ... I haven't updated since 3 years.. My system was very stable before all that happened..
Sony VAIO PCG-61A14L
The yellow exclamation point is on the WLAN .
This is a copy and paste of the WLAN error code in Device Manager:
"This device cannot start. (Code 10)
{Operation Failed}
The requested operation was unsuccessful."
I guess it might be helpful to mention that the Wlan has a physical ON/OFF switch..
So If it is off the wlan is cut off as if it doesn't exist just like it is now , except now, the switch doesn't have any effect..
As for the USB port there is no indication of the malfunction except that I get a Windows notification when I stick a flash drive in it:
"The USB device is not recognized" and also tells me it malfunctioned and Windows does not recognize it..
But Ofcourse, my other USB ports are working perfectly, and my flash drive is just fine..
Make and model info for the WLAN.
Also run "ipconfig /all" (without quotes) via the Command Prompt.
Copy and paste the full results here.
Intel Centrino Advanced N 6200 AGN
Microsoft Windows [Version 6.3.9600]
(c) 2013 Microsoft Corporation. All rights reserved.
C:\Windows\system32>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Admin
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Ethernet:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Qualcomm Atheros AR8151 PCI-E Gigabit Eth
ernet Controller (NDIS 6.30)
Physical Address. . . . . . . . . :
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Unknown adapter Local Area Connection 5:
Description . . . . . . . . . . . : TAP-Windows Adapter V9
Unknown adapter Local Area Connection 4:
Description . . . . . . . . . . . : Windscribe Windtun420
Unknown adapter Local Area Connection 3:
Description . . . . . . . . . . . : Windscribe VPN
Ethernet adapter Ethernet 6:
Description . . . . . . . . . . . : TAP-BVPN-Windows Adapter V9
Unknown adapter Local Area Connection:
Description . . . . . . . . . . . : Speedify Virtual Adapter
Ethernet adapter Ethernet 4:
Description . . . . . . . . . . . : Symantec TAP Driver
Unknown adapter HotspotShield Network Adapter:
Description . . . . . . . . . . . : HotspotShield TAP-Windows Adapter V9
DHCP Enabled. . . . . . . . . . . : No
Unknown adapter VPN - VPN Client:
Description . . . . . . . . . . . : VPN Client Adapter - VPN
Unknown adapter Local Area Connection 2:
Description . . . . . . . . . . . : TAP-ProtonVPN Windows Adapter V9
Ethernet adapter VirtualBox Host-Only Network:
Description . . . . . . . . . . . : VirtualBox Host-Only Ethernet Adapter
Autoconfiguration IPv4 Address. . : (Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
NetBIOS over Tcpip. . . . . . . . : Enabled
I have to mention that I did try to disable all these VPN adapters, and I also tried a tool called Complete Internet Repair and checked the following :
I also tried the command "NETCFG -d" in CMD
This adapter?
It is not listed in "ipconfig /all"
And I am not at all sure about:
"I guess it might be helpful to mention that the Wlan has a physical ON/OFF switch.."
Do not remember any WLANs having such a switch. Do you have any photographs or links that show the switch?
If you right click the Centrino adapter in Device Manager then select Properties is there anything listed under the Events tab?
And, just to clarify, the USB port works when other devices are connected but not when a flash drive is connected?
Likely there are multiple problems - Windows 8.1 and the laptop itself. May be starting to falter and fail.
Is all important data backed up?
This adapter?
yes the data is backed up, still, i don't want lose my Windows customizations ...
"And, just to clarify, the USB port works when other devices are connected but not when a flash drive is connected?"
,No, the USB port is NOT working with any device, however, power is transmitted and the optical mouse does emit light..
"If you right click the Centrino adapter in Device Manager then select Properties is there anything listed under the Events tab?"
"Do not remember any WLANs having such a switch. Do you have any photographs or links that show the switch?"
What do you mean? older laptops used to have those, mine looks similar like the picture below:
Review Sony Vaio VPC-F13Z1E/B Notebook - NotebookCheck.net Reviews
I just had a strange idea, what if the drivers responsible for the switch are separate from the WLAN drivers?
If that is true then reinstalling those drivers might solve it..
The only problem is that I just don't know which driver is it.. I don't know what to look for..
I also wonder if the motherboard could have been damaged because of the dust?
I misunderstood then.
I had it in my mind that you were using a USB wireless network adapter and that the switch was on that adapter and not on the laptop.
The laptop switch likely toogles the laptop between wired and wireless with respect to using network components within the laptop. No dedicated drivers for the switch that I am aware of. However, there is some code somewhere that tells the host computer what method of network connectivity is selected: wired or wireless.
The switch would not/should not affect a USB installed wireless network adapter. That would cause all sorts of problems if other USB devices are plugged in.
Computers ( barring special requirements) should only have one network adapter enabled at a time.
For testing purposes are you able to use a wired connection and then, once connected and stable, run "ipconfig /all" again?
As for dust damaging the motherboard - only if thick and heavy enought to cause serious overheating,
Computer may be able to shut itself down should that be the case - overheating/thermal shutdown.
Or the dust draws in crawly things that can short things out and fry themselves and small components.
More damage is done by rough and improper cleaning procedures.
Sure, Can I just use my WiFi dongle instead? I must say however, last time, I had unplugged the WiFi dongle that I have showing up right now...
DNS Suffix Search List. . . . . . : home
Wireless LAN adapter Local Area Connection* 12:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Wireless LAN adapter Local Area Connection* 5:
Description . . . . . . . . . . . : Microsoft Hosted Network Virtual Adapter
Wireless LAN adapter Wi-Fi 3:
Connection-specific DNS Suffix . : home
Description . . . . . . . . . . . : 802.11n USB Wireless LAN Card
IPv4 Address. . . . . . . . . . . : 192.168.1.3(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Tuesday, August 6, 2024 9:14:12 AM
Lease Expires . . . . . . . . . . : Tuesday, January 19, 2038 5:14:06 AM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 192.168.1.1
192.168.1.1
I am humbly saying, I cannot see we are making any progress..
This is showing that the issue is with your internal WiFi, rather than the USB adapter. If Device Manager consistently looks this same way, your USB WiFi should be working, but your internal WiFi card installed by Sony is not.
That would be the only one that the switch toggles. Some systems do use a driver for that, and as annoying as Sony is with their drivers, I wouldn't put it past them that it's some hard-to-find driver that if it's corrupted, you may struggle to find a copy anymore. But that's not relevant to the USB adapter. Code 10 is usually either a bad WiFi card driver, or bad card altogether.
Ideally, as long as that USB adapter isn't having trouble being recognized in a good port, this should be permissible and you should be able to get online even with the bad internal WiFi.
With the bad USB port you described, if no device is recognized in that port then you likely have a bent/broken pin in the port, and that port can no longer be used. I would use another port, and if you're running out of ports, you can use a USB hub to get by in the meantime before you replace the laptop.
Reactions: hosa
Re: "I am humbly saying, I cannot see we are making any progress.."
Agree - but that is sometimes the nature of troubleshooting from "afar".
Noted:
"Lease Obtained. . . . . . . . . . : Tuesday, August 6, 2024 9:14:12 AM
Lease Expires . . . . . . . . . . : Tuesday, January 19, 2038 5:14:06 AM"
13+ years - not at all expected.....
Confirm make and model router.
Verify that the DNS server is 8.8.8.8 and 8.8.4.4
Change the IP address lease time to 7 days - does doing so help?
Yes, There are no problems with the usb WiFI dongle, I am using it because I have to, but I don't want to, I want to fix the internal one.. My technician told me he put another WLAN card inside my laptop (one he knows that it works) and it didn't work for him... Plus my own wlan card works in Ubuntu Live USB... I am going to perform a an offline CHKDSK (because I think that is the only option I have left before reinstalling Windows).. Ill keep this thread updated....
Regarding the bad USB port, I can do what you have suggested.. I think my technician would have noticed a bent/broken pin in the port...
I had noticed the bad USB port after the laptop was returned to me, but I cannot say for sure when or how exactly the damage was done.
I did not see anything wrong in his cleaning technique (I was there) he did it with a brush... One that is similar to a paint brush...
Noted:
Thank you for your patience with me.. :)
I use Libre DNS... Do I really need to change to Google's?
Its a Cheap Chinese router, I am not comfortable publishing the make and model since it probable has security like swiss cheese..
I have looked through my router's settings, but I cannot find this particular setting..
It probably just doesn't even offer it.. My previous models haven't offered it either..
Not familar with Libre DNS.
Try Google's DNS and if it is better okay. If not switch back.
As for the make and model router that in and of itself is not a problem unless you reset the router to the factory settings and did not change the default login name and password. The bad guys know the default settings very well..... In a wireless environment the router would be wide open.
Go to the manufacturer's and look for the User Guide/Manual.
Likely that the router is using 192.168.1.1 but there are other commonly used default IP addresses.
You enter the Router's IP address into your browser and then the login window appears.
However, some manufacturers make you login into the manufacturer's website for router administration.
Should not be necessary and if so - that is not a router I would use.
(I have a Linksys WRT 1900 AC using 192.168.1.1 and manage my router settings directly.)
FYI:
https://www.techspot.com/guides/287-default-router-ip-addresses/
and:
What you do not want to post is the IP address provided to your router by your ISP.
That is the address given by "What is my IP".
Could be that the router simply obtains the current date and time and adds 13 years for lease time.
I was actually mistaken, I was thinking of sfc /scannow which is the appropriate function, NOT CHKDSK
Edit: I have now finished performing a DISM repair then SFC SCANNOW but my wlan still hasn't been fixed.. 🙁 : (
I have seen an incompatible WiFi card upgrade cause this error, though if your original had the same Code 10 issue, that would suggest either more of a software issue. Or perhaps there's an issue with your mPCIe slot in addition to that USB port.
It's difficult to say for sure what is going on. Normally at this point I'd try a fresh Windows install on a different hard drive just to see what happens, but if that is not doable I think it is best just to live with using the USB adapter.
I'll add though, running chkdsk certainly wouldn't hurt. I've seen disk corruption cause strange issues.
Reactions: hosa
My issue has been SOLVED.
I solved it when I remembered that one week prior (problems didn’t appear right away) I updated my drivers with a third party Driver Updater..
And then I also remembered that I HAD UPDATED THE BIOS using that program . So turned out that BIOS was fake or illegitimate .. I installed the “older” BIOS and restarted..
Wala , no more wlan or Bluetooth issues..
Unfortunately this phenomenon is not well known among experts and hopefully this turns up in search when users look for the solution..
NEVER I mean NEVER use third party driver updaters.
Even windows will install the wrong driver.
Luckily for you the wrong bios did not completely brick the laptop.
Reactions: hosa
