[SOLVED] WLAN is isolated from LAN
Oct 23, 2019
5
My router seems to separate WLAN connections from LAN. I can't run media servers over LAN because of this. Is there a way to bridge these connections?
Yeah, I checked the router's setting and the instruction manual, there's nothing there regarding wlan isolation. I've called my ISP but the call center agents aren't exactly wiz kids.
*edit
My router is a FiberHome AN5506-04-FA supplied by my ISP.
Check different lan ports on router. Some of them may go through NAT, some without NAT.
It looks like under Network/Broadband settings/Connection Type.
"Bridge" setting - would pass internet to lan ports without NAT and
"Route" setting - would make them go through NAT.
Wifi would go through NAT always, you want lan ports go through NAT too.
http://www.3bb.co.th/uploads/20180209185409FiberHome AN5506-04-FA_Eng(1).pdf
