Question worked perfectly, swapped case now pc takes 3- 4 seconds to start turning on, cpu debug led is on, and no signal to monitor
Jan 2, 2024
everything was fine then i upgraded to a new case and now it cpu debug led is on, pc takes 4 seconds to start turning on and there s no signal to my monitor
things i ve tried:
removed cmos battery and reset cmos
swapped rams into different slots (the a2 slot worked as in i had signal but after 3 boots it also stopped working)
reseating cpu
reconnecting all the cables
swapped gpus
i just bought the cpu and mother board last month i really hope they aren t broken
Components: cpu ryzen 5 5600
motherboard msi b550m pro vdh
case: gladius pro gaming argb
gpu gtx 1650 4gb oc
psu woden 650w
1tb ssd m2 crucial
2x8 gb ram corsair vengeance 3000mhz
i think i tried everything though its weird it worked for a few boots with one stick of ram in the a2 slot but then it didn t work anymore
so is the mobo the issue? i still have warranty for it
Double check the Motherboard's User Guide/Manual.
Some motherboards require that the first physically installled RAM be placed in a specific slot - likely DIMMA2 if applicable to your motherboard.
The User Guide/Manual should provide a listing of supported RAM and supported RAM configurations.
Also check MSI's website for updated details.
