Question Would CMG32GX4M2D3600C18 work with ASRock B660M Pro RS?
reapzstar
154
6
18,695
I do not see it on the supported memory list on ASRock's website.
Will it not work with the motherboard, should I cancel my order on it?
I thought it would be a perfect match, didn't even bother checking to be honest.
Please advise.
Thanks in advance for every answer!
What processor are you looking to pair with that motherboard? You should be able to work with that ram kit on the motherboard listed above. Pretty much every ram kit on the market, so long as it complies with the ram slot on the motherboard, should work out of the box. If you want to remove doubt from your build/purchase, you can stick to the memory QVL list on ASRock's site for the motherboard though finding the exact ram kit is often times more challenging than rocket science.
