I bought the new ryzen 7 3700 and it comes with the wrath cooler obviously..
My question is about its connections..
Firstly, it only came with the USB cable, there wasnt even a rgb header cable inside of the box..
But I seated the CPU, put the cooler on top and latched it, and plugged in the power cord attached to the cooler...
With only the power cord plugged in,
I turned on my pc, and the fan turned on and fan is lighting up colorful..
are the other 2 small cords (USB or rgb) actually needed for performance? Or just give me the ability to control the lights?
Do I technically need either of them? And while using them, do I need both plugged in at the same time or just whichever I choose?
