Question Xeon CPU temp going above 80c.
Jan 23, 2019
6
Hi guys, I recently bought lenovo s20 system with w3565 cpu and rx 470.
Now when I play csgo on it the temperature of cpu goes above 80c and the fans starts making very loud noises. The idle temperature of cpu is around 60c-70c. Are those temperatures dangerous?
not dangerous but too high. Reapply thermal paste and clean the fan/cooler of the CPU
which cooler is it? Eventually you will need to get a better one, which can cool down your 130Watt CPU
Unfortunately I don't know about the cooler, Is Arctic Siver 5 would be a good thermal paste?
WOW, the Xeon W3565 is a 130w TDP chip at stock clocks. It's a 45nm fab chip, so don't expect the best efficiency, expect lots of heat. That taisol cooler doesn't even spec a TDP figure, but I highly doubt it's capable of cooling a 130w chip. It's more than likely only capable of working on a 65w max tdp cpu.
You need to find a cooler that's actually spec'd for at least 130w tdp.
