Hello everyone.
I have been waiting several months for my new XFX 7950GT card. I replaced my previous 6800 card with the new card and installed the 93,xx drivers from nvidia.com, after uninstalling the old ones of course (normal uninstall).
This is a stock Dell 9100 computer.
Then I went to run 3DMark05. Half way through the test the screen went black, came back on with weird colored dots on the screen. I simply got a broken image. Then the screen went black again, and again the colored dots appeared, and then the computer froze, so I rebooted. 8O
I tried running a game, and the screen showed the colored dots and froze.
So I tried uninstalling the drivers again, and install the ones that came with the card (on the CD) (91,xx drivers).
I rebooted again... Appearently installing the new drivers didn't help. This time colored dots appeared already after logging in to windows.
So I turned off the computer, waited a little while, and went into the BIOS to check the settings there. Even here the computer froze after the dot-filled screen again.
I rebooted, successfully logged back into windows, and saw that the GPU core temperature was stable at 40C... :roll:
My specs (DELL Dimension 9100):
P4 3,0Ghz Dual CPU
XFX 7950GT eXtreme (manufactor overclocked) (NON-SLI)
SB Audigy 2
2,0GB Memory
2x 250GB Hard drive (@ RAID Stripe)
PSU: 375W
My friend tells me it might be a driver problem.. But how can it be a driver problem when I even get the problem in the BIOS? Even before starting Windows?
I think the problem might be not getting enough power from the PSU, as the card needs additional power, but I can't say this for sure at all.
Is it because it is a DELL computer, or because 375W PSU isn't enough, a driver conflict or what?
PS: I tried replacing the new card with the old 6800, and there are no freezes yet (not even after 3Dmark05)
Any help would be greatly appreciated.
P4 3,0Ghz Dual CPU
SB Audigy 2
2,0GB Memory
PSU: 375W
