javmaher
How can I remove the login request from my XP PC? This message will disappear with pressing OK.
Thanks for your help.
Click Start> Run and type: control userpasswords2
Click OK
The [User Accounts] Property Sheet displays.
On [Users] tab, clear the [Users must enter a user name and password to use this computer] check box.
Click [Apply].
Enter a user name and password that should be used to logon automatically in the dialog box that appears.
Click [OK].
Go to [Control Panel] [User Accounts] [Change the Way Users Log On and Off].
Uncheck [Use the Welcome Screen] and [Use Fast User Switching]
