XP Pro CD & booting problem
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
Hello
When using the Windows XP Pro CD to boot, the process gets as far as the
"Set-up is inspecting your configuration" stage, then the screen goes
blank and nothing happens. This didn’t happen before (I format and
reinstall every 3-4 months). Other bootable CD’s work fine, e.g.
Windows 2000 Pro.
I have a dual boot setup for Windows XP Pro and SuSe 9.2.
Any help is appreciated,
Craig.
"The object of war is not to die for your country but to make the other
bastard die for his."
It seems the problem is with this Windows XP cd.
Jonybrv
"Craig H." wrote:
> Hello
> Windows 2000 Pro.
> Craig.
"This didn’t happen before (I format and reinstall every 3-4 months)"
What an earth for?
Youve probably warn out the wincd
"Craig H." <spam@thehurley.com> wrote in message
news:%23GDDHiraFHA.3328@TK2MSFTNGP09.phx.gbl...
> Hello
> Windows 2000 Pro.
> Craig.
> What an earth for?
>>Hello
>>Windows 2000 Pro.
>>Craig.
Sorry, I should have also stated that this particular Windows XP Pro CD
boots perfectly on any other computer I try. So nothing on the CD is
worn out
Regards,
Craig.
"Whether you think that you can, or that you can't, you are usually right."
