Xp Pro will not restart
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
Reconfigured to prior date, lost power during restart, what can I do (do not
have original install disk)
greenwn typed this:
Use a BART BOOT CD and swap out your HIVES... see if it helps.
Rich "Doc" Colley
mailto: pc-dc-doc@nospam.comcast.net
Hey Greenwn,
Can you describe what the problem is exactly?
What error message(s) do you see if any?
Please be as descriptive as possible. Much thanks.
Craig
Microsoft Setup Team
Search our Knowledge Base at http://support.microsoft.com/default.aspx
Visit the Windows 2000 Homepage at
http://www.microsoft.com/windows2000/default.asp
See the Windows NT Homepage at
http://www.microsoft.com/ntserver/
NOTE: Please reply to the newsgroup and not directly to me. This allows
others to add to and benefit from these threads and also helps to ensure a
more timely response. Thank you!
This posting is provided "AS IS" without warranty either expressed or
implied, including, but not limited to, the implied warranties of
merchantability or fitness for a particular purpose.
The views and opinions expressed in this newsgroup posting are mine and do
not necessarily express or reflect the views and / or opinions of
Microsoft.
Craig:
The problem is that when I reboot, the XP Professional Startup page is
displayed, but the error message
of "Windows was not properly closed, due to error or power interuption (I
will write down the exact verbage tonite). I tried to F8 at startup, but
every option I have will eventually go to a blank screen (my mouse cursor
still is displayed though). As I indicated, I do not have the install
software, it was installed by an individual that is overseas presently (it
was a present from my daughter). So any assistance would be greatly
appreciated.
Thanks in advance, Bill
""Craig"" wrote:
> Hey Greenwn,
> Craig
> Microsoft.
Doc:
I am not sure what the BART BOOT CD is, I am not very computer litterate. Is
it something that I can purchase myself, our does someone with a MicroSoft
license have to use it?
Thanks for the reply, Bill
"Doc" wrote:
> greenwn typed this:
> Rich "Doc" Colley
