XP sp2 ADM settings not visible
G
Guest
Guest
Archived from groups: microsoft.public.win2000.active_directory (More info?)
Hi
ive been trying to get various settings for sp2 going in group policys. the
issue i have is this.
first i got string to long but then applied the updates etc.. to fix that.
then I was able to add the adms to administrative templates but i cant see
any of the policy settings i should see. like the firewall settings for
example.
when i load the same adm files into a 2003 domain controler i see all of
them. however on this domain we dont have a 2003 domain controller so are a
little bit stuck 🙁
the sp2 adms have alot of featuers we would realy like/need but the settings
just arnt visible 🙁
is there anyway i can view and edit them ?
btw im doing this through the "active directory users and computers" panel.
Any help would be GREATLY apreshiated.
G.Davies <G.Davies@discussions.microsoft.com> wrote:
> Hi
> policys. the issue i have is this.
> that. then I was able to add the adms to administrative templates but
> i cant see any of the policy settings i should see. like the firewall
> settings for example.
> of them. however on this domain we dont have a 2003 domain controller
> so are a little bit stuck 🙁
> settings just arnt visible 🙁
> panel.
I believe this sounds like what you need, it worked for me.
The following entry in the [strings] section is too long and has been
truncated" error message when you try to modify or to view GPOs in Windows
Server 2003, Windows XP Professional, or Windows 2000:
http://support.microsoft.com/default.aspx?kbid=842933
Best regards,
Kevin D4 Dad Goodknecht Sr. [MVP]
Hope This Helps
When responding to posts, please "Reply to Group"
via your newsreader so that others may learn and
benefit from your issue, to respond directly to
me remove the nospam. from my email address.
http://www.lonestaramerica.com/
Use Outlook Express?... Get OE_Quotefix:
It will strip signature out and more
http://home.in.tum.de/~jain/software/oe-quotefix/
Keep a back up of your OE settings and folders
with OEBackup:
http://www.oehelp.com/OEBackup/Default.aspx
Thanks for the reply. but this hasnot helped.
i dont get the string to large errors. wich is good but i dont get any of
the new adm features such as firewall and many many many others.
> > Hi
> > panel.
> Best regards,
> Hope This Helps
> with OEBackup:
> any of the new adm features such as firewall and many many many
> others.
Did you edit the Group Policy from an XP SP2 machine. Once you edit the
policy from an XP SP2 machine it upgardes the GPO.
Upgrading Windows 2000 Group Policy for Windows XP:
http://support.microsoft.com/default.aspx?scid=kb;en-us;307900
Best regards,
Hope This Helps
with OEBackup:
How do you mean edit from an xp sp2 machine ?
im not sure how to edit the domain group policy from a workstation.
but should like thats what i need to do.
> > others.
> Best regards,
> Hope This Helps
> with OEBackup:
It's in the Article, did you read the article I posted?
Here it is again:
Best regards,
Hope This Helps
with OEBackup:
ok well i have followed that and it and the settings were there, however when
i go to a domain controller i cant see the settings
is that what you would expect or is something wrong ?
> Here it is again:
> Best regards,
> Hope This Helps
> with OEBackup:
