XP SP2 Problems
jay
581
Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
I have installed SP2 about 4 times. Each time it installs okay, I use
Ad-Aware to scan the hard drive and clean up any unwanted software/spyware
and installed the most recent BIOS for XP SP2 as recommended by Dell. SP2
usually works fine for about a week up to 3-4 weeks. Then out of the blue I
will start up my computer and receive start-up failure in which case I have
to start up in Safe Mode and use System Restore to go back to uninstall SP2.
I have reviewed all the "before you install SP2" instructions from both
Microsoft and Dell and I am still unable to keep SP2 in use. Any
suggestions? Thanks in advance!
Jay;
Why do you think this is an SP-2 issue?
When you System Restore back before SP-2, you also go back for
everything else.
It would be extremely unusual for anything to have such a delay.
What else happens at the time of the problems?
Jupiter Jones [MVP]
http://www3.telus.net/dandemar/
"Jay" <Jay@discussions.microsoft.com> wrote in message
news:E125DB7C-1640-45FF-8423-0AB50F33C9E3@microsoft.com...
>use
> software/spyware
> Dell. SP2
> the blue I
> I have
> uninstall SP2.
> both
You need to remove spyware and viruses *before* you install SP 2 - not
after. Your hard disk must be absolutely clean of any trace of spyware and
viruses in order to successfully install a service pack.
Since spyware is so difficult to remove, most people use more than one
anti-spyware application. And it sometimes takes several passes before an
infection is removed. Unfortunately, sometimes it's impossible to completely
remove spyware or viruses.
Once the infection is completely gone - or after you've reinstalled all your
software, if need be - then you must focus on avoiding this malware. If you
aren't able to keep spyware and viruses off your computer, then it's only a
matter of time before you'll find yourself in trouble once again.
Ted Zieglar
> blue I
> have
> SP2.
Thanks Ted,
I ran the Ad-Aware priot to downloading SP2 and ran it several times untill
everything was gone, also manually downloaded my virus definitions and did a
full virus scan. I will try downloading another program for spyware also.
> Ted Zieglar
> > blue I
> > have
> > SP2.
Hi
Do yuo see any error message prior to the problem occuring? If not, have a
look in the Event Viewer to see if any entries there may point towards the
problem.
Will Denny
MS-MVP - Windows Shell/User
Please reply to the News Groups
> blue I
> have
> SP2.
Thank you Will,
I went to the event viewer, not sure what I am looking for, I copied 12
system events and 4 application events as noted below. I did not see
anything else that would give me a clue. These are the events that started
during the last successful logon and the last time SP2 failed...I am assumimg
this is SP2 related. Any suggestions? Thanks again!
SYSTEM: (not sure what is relevent and what is info only)
1) Microsoft (R) Windows (R) 5.01. 2600 Service Pack 2 Uniprocessor Free.
2) The Event log service was started.
3) DCOM got error "This service cannot be started in Safe Mode " attempting
to start the service netman with arguments "" in order to run the server:
{BA126AE5-2166-11D1-B1D0-00805FC1270E}
4) DCOM got error "This service cannot be started in Safe Mode " attempting
to start the service EventSystem with arguments "" in order to run the server:
{1BE1F766-5536-11D1-B726-00C04FB926AF}
5) The SYMTDI service depends on the TCP/IP Protocol Driver service which
failed to start because of the following error:
A device attached to the system is not functioning.
6) The DHCP Client service depends on the SYMTDI service which failed to
start because of the following error: The dependency service or group failed
to start.
7) The DNS Client service depends on the TCP/IP Protocol Driver service
which failed to start because of the following error: A device attached to
8) The TCP/IP NetBIOS Helper service depends on the AFD Networking Support
Environment service which failed to start because of the following error: A
9) The IPSEC Services service depends on the IPSEC driver service which
failed to start because of the following error: A device attached to the
10) The following boot-start or system-start driver(s) failed to load: AFD,
Fips
IPSec, MRxSmb, NetBIOS, NetBT, Processor, RasAcd, Rdbss, SAVRT, SAVRTPEL,
Tcpip
11) DCOM got error "This service cannot be started in Safe Mode "
attempting to start the service EventSystem with arguments "" in order to run
the server:
APPLICATION:
1) wuauclt (2240) The database engine stopped.
2) wuaueng.dll (2240) SUS20ClientDataStore: The database engine stopped the
instance (0).
3) The description for Event ID ( 1800 ) in Source ( SecurityCenter )
cannot be found. The local computer may not have the necessary registry
information or message DLL files to display messages from a remote computer.
You may be able to use the /AUXSOURCE= flag to retrieve this description; see
Help and Support for details. The following information is part of the event:
"Will Denny" wrote:
> Hi
> problem.
> Will Denny
> > blue I
> > have
> > SP2.
Hi
Do you have any specific problems with Windows Update? What kind of
Internet connection have you got? Dial-up or Broadband?
Will Denny
news:558E5BDF-A1F2-4886-92BC-0C4FA660E2FA@microsoft.com...
> Thank you Will,
> started
> assumimg
> attempting
> attempting
> server:
> failed
> to start.
> to
> Support
> A
> AFD,
> Fips
> Tcpip
> run
> the server:
> APPLICATION:
> the
> instance (0).
> computer.
> see
> event:
> "Will Denny" wrote:
>> Hi
>> a
>> the
>> problem.
>> Will Denny
>> > software/spyware
>> > SP2
>> > blue I
>> > have
>> > SP2.
Denny,
I have absolutely no problems with Windows Update, SP2 downloads perfectly
everytime and installs okay. Unfortunately, I have dial-up (cable/dsl is not
available yet here...one more month DSL will be available). As I mentionrf
before, SP2 works okay for a while (generally 3-4 weeks) unlike this time it
only lasted 6-days. Then all of a sudden after no program changes or
software upgrades or additions I can only start up in Safe Mode until I
remove SP2.
"Will Denny" wrote:
> Hi
> Will Denny
> > Thank you Will,
> > started
> > assumimg
> > attempting
> > attempting
> > server:
> > failed
> > to start.
> > to
> > Support
> > A
> > AFD,
> > Fips
> > Tcpip
> > run
> > the server:
> > APPLICATION:
> > the
> > instance (0).
> > computer.
> > see
> > event:
> > "Will Denny" wrote:
> >> Hi
> >> a
> >> the
> >> problem.
> >> Will Denny
> >> > software/spyware
> >> > SP2
> >> > blue I
> >> > have
> >> > SP2.
Hi,
Doesn`t sound like a SP2 problem, especially if everything is working for
several weeks. Seems like something else is causing your problem. I
haven`t had any problems on computers I updated to SP2 that I maintain.
Jeff
"Jupiter Jones [MVP]" <jones_jupiter@hotnomail.com> wrote in message
news:uLPP7e6yEHA.1300@TK2MSFTNGP14.phx.gbl...
> Jay;
> When you System Restore back before SP-2, you also go back for everything
> else.
> Jupiter Jones [MVP]
>> software/spyware
>> SP2
>> blue I
>> have
>> SP2.
Jeffrey,
As I just wrote to Jupiter Jones, the last time I updated to SP2, other than
email, I did not download, update or install anything (except XP & Virus
updates). I did not even change any settings. So I am baffled. I may just
go without SP2 for a while to see if I have any problems. You are both
right, it may not be a SP2 problem, may just be a coincidence. (????)
"jeffrey" wrote:
> Hi,
> Jeff
> > Jay;
> > else.
> > Jupiter Jones [MVP]
> >> software/spyware
> >> SP2
> >> blue I
> >> have
> >> SP2.
