G
Guest
Guest
Archived from groups: rec.audio.tech (More info?)
I had a chance last night to check the cables and guess what - you guys were
right (not that I ever doubted you).
I was doing this based on memory and my memory told me that those
connections were all MIDI cables and connectors - I remembered not really
looking at the pins and just turning the connectors until the indent fit, so
I just assumed they were MIDI cables, and, truth be told, if you had quizzed
me before this I wouldn't have been able to tell you how many pins are on a
MIDI cable - I was going on exterior appearance alone.
They are in fact 8 pin (or is it 8 din?) cables, the ones Yamaha provides
with the unit.
Nonetheless, it still confirms what I've been saying - that the Clavs are
connected to the Teacher's console with an Audio signal only - From the clav
HP out, to the MLA100 box, through the 8 pin cable to the teacher's console
(and HPs).
The ONLY MIDI connection is from the USB port of the Mac to the Clav (MIDI
In/Out via MidiSport USB interface).
I have not yet checked the ideas that Tim (IIRC) gave me (I was busy last
night and only had time to check the cables). But now this is cleared up
maybe it will eliminate some of the guesswork I've unfortunately presented
you guys with.
Thanks,
Steve
with the unit.
(and HPs).
you guys with.
Thanks,
Steve
