Question 144HZ monitor cabels pls help
Btw I have a dvi-d dual link cabel and when i plugged it into the monitor and the gpu the monitor said Incorrect cable. Why?
Depends what your monitor has on it
These cables are all slightly different - check your pins on cable and the slot they go into
QUOTE="bignastyid, post: 21041773, member: 516849"]
In the product description area, 2nd line under specification.
[/QUOTE]
Ty but it will be hard for me to find a dvi cable because i live in hungary so i cant order from amazon
