34 pin fdd to usb
mvans1117
Is there any way to get info off of 5.25 floppies? I have the internal disk drive but no way to hook it up to a computer.
Youtube Video how-to on that adapter here:
https://www.youtube.com/watch?v=sm4noM4TCsg
Also shows optional hardware case, cable and power supply available to create an external 5¼" floppy drive. NOTE the system only READS the floppy - does not write - and it simply creates a disk image on your HDD as a file. Comes with software to use the reader - the floppy is not directly accessed within Windows Explorer - and to use the files from the floppy. HOWEVER, there's a real bonus - the software can handle disks from several older hardware and OS systems, not just DOS or Windows on IBM PC-type systems.
Review of system here:
http://ascii.textfiles.com/archives/2503
