Question 3700x hight temps at idle
Aug 4, 2024
11
My Ryzen 7 3700x is crazy overheating on idle with the stock wraith prisme and arctic mx-4 applied using an b550m pro4 with stock settings and PBO disabled , core perfomance boost is enabled idk how and why ,cpu usage is under 2 percent btw
https://ibb.co/B3vF0Fj
With a 3700x you can't use the Curve Optimizer but you can manually undervolt it to get better temperatures. Additionally, you can make sure performance mode or similar mode is active in the BIOS for the HSF instead of a "normal' or "silent" mode. You can also manually setup the HSF profile in the BIOS to ramp up according to temperature thresholds.
im using my own fan curve instead of perfomance mode the curve is loud even tough the cpu is hot with core perfomance boost enabled and with no CPB or PBO it gives an idle oof 47 degat static speed of 3.59 ghz
Just invest in better cooler, those OEM are barely enough. If it's static frequency at 3.9GHz on all cores,that's nowhere close to idle, at true idle all cores but one or two would be in sleep mode and those active around max 1GHz.
i managed to lower the idle to 46 deg but with loosing alot of perfomance running the cpu at max of 3.5 ghz and using only 6 cores the problem is my fan curve has a minimuim of 65% at 40 deg idk how the cpu is not reaching 30 deg
Just how "Idle" is your idle, CPU usage should be no more than1%.
its 1 to 2 percent of usage and most cores shown as sleep on ryzen master also when gaming some intense cpu games the cpu max temp is 55 deg to 60 at max lol even with Cinebensh r20 it reach an temp of 65 at max so idk why t he idle is 47 and with CPB its 65 at idle
how do you check the frequency? try using the windows task manager,monitoring tools could clock up the CPU while using
geforce experience installed? uninstall and restart windows
as well as ryzen master
afther installing win10 the cpu idle at 47 deg wich is way better than old 64 deg idk why but there another crazy thing im using 4 dimms of ram 4gb +4gb micron 2400 mhz dim +8gb crucial 3200 mhz + 8gb samsung 3200 mhz so 24 gb at total running all of them at speed of 3200 and timing of cl22 in bios ,afther removing the 2 micron dimms and running only with both samsung and crucial 3200mhz the cpu temp droped to 37 deg at idle and 70 underload idk how even this is related to cpu but just fixed this anyway
Those "Fixes" are just lowering performance but are not even necessary or fixable with better performance by using better cooler. Max temps at high, continuous loads are way more important.
im planning to get an deepcool ak620 its cheaper here and gives some good cooling perfomance but there is somthing wierd my cpu boost to 1.431V with stock bios settings even tough i set PBO from auto to disabled
Your temp and CPU speed while you did the screenshot is fine, not even close to overheating and that's with the CPU boosted to 4.3 ghz.
Is it actually overheating while gaming or any CPU intensive task?
its idle the cpu is boosting to these speed on idle with no app open and yes also there is no BG tasks as i modify my windows so it keep cleanwith only 60 proccess in task manager im not comfortable with these temps at idle
