Recently, I bought a gtx 970 which is powered through an 8 pin PCI-E connection. My power supply only has a double 4 pin 12V connector. As far as I've heard, these are only for the motherboard or CPUs, but it fits into the PCI-E slot. Will it work?
Thanks. I just overlooked that one 😀NOPE. That ATX power cable isn't meant to power up a gaming card. You need to use the PCI-E connectors from your PSU. Are you sure that cable fits in the GPU's PCI-e slot (doubt it) ? Which PSU Model do you have ? Look for these cables:
