Hi guys, this is to all the V8 owners out there (and people in the know). Has anyone reached 4 ghz on a cooler master V8 and had decent temps <70C under load (prime95 for example). I'm at 3.8 ghz on my i7 920, under load I can go as high as 75C at times. For thermal grease I used Arctic MX-3 applied using the single line method. The main purpose of this post is judge my results with the V8 against others to see if this is typical V8 performance or if I need to re-install the cooler again. My goal is to get my i7-920 to 4.0 ghz with temps under 65C under load. Possible with the V8? What do you think?
My Build:
Cooler Master HAF 922 Case
Antec Neo Power 500W PSU
Asus P6T Mobo
OCZ 6gb DDR3 Ram
EVGA GTX 260 Video card
2x WD Black 640 GB HDDs
Cooler Master V8 CPU cooler
Intel i7 920 CPU
My Setup:
OC: 3.8 ghz
Ai Tweaker: Manuel
Ai Overclock Tuner: 8-8-8-24 (my ram was not XMP so I entered manuel timings)
CPU Ratio Setting: Auto (20)
Intel SpeedStep Tech: disabled
Intel Turbo Mode Tech: disabled
Bclk Frequency: 190
PCIE Frequency: 100
DRAM Frequency: DDR3-1520
UNCLK Frequency: Auto
QPI Link Data Rate: Auto
CPU Voltage: 1.21250
CPU PLL Voltage: 1.88
QPI/DRAM Core Voltage: 1.21250
DRAM Bus Voltage: 1.66 (when you type 1.65 it changes to 1.66 automatically)
CPU Differential Amplitude: 800mV
Intel HT Technology: Enabled
PS: At this point I'm not willing to do any lapping (in case someone was heading in this direction)
My Build:
Asus P6T Mobo
OCZ 6gb DDR3 Ram
Intel i7 920 CPU
My Setup:
OC: 3.8 ghz
Ai Tweaker: Manuel
Bclk Frequency: 190
PCIE Frequency: 100
