Hi guys, first off thanks in advance for any replies. I’ll try to be as thorough as possible about my issue.
specs:
5600x (stock cooler awaiting AIO)
B550f ROG STRIX mobo
850w psu
3080 ftw3
16gb ram @ 3600 cl16
issue:
If you need any info, logs, or screenshots, please let me know.
After I put my build together, it worked great. The 5600x temps weren’t great, but they certainly were not bad at all. On average, I would get about 40-50 degrees at idle, and 60-70 degrees at heavy load, with blips to 80 degrees.
after some time, I realized I had put my case fans in the wrong orientation, making airflow worse. Last night I went in and flipped the corresponding fans around, and indeed made my temps better on my GPU. However, now randomly, which i do not believe was happening before, my 5600x is spiking in clock speeds and temps, resulting in my CPU_FAN to go full blast. I completely understand that Windows may cause this from random processes in the background, however with no programs open, my CPU is spiking in core clocks (maxing out ALL cores) and in temperature for a few seconds before calming down. The result of this is that my fans go absolutely nuts, then silent, then nuts again all within a matter of 5-10 seconds.
again, I understand high temps are normal here and there, but I know for a fact that my CPU_FAN was not getting to 100% basically ever before switching my fans around, and certainly remained silent when idling at desktop.
I used HWINFO64 to monitor the fans and clocks, and I confirmed that whenever my CPU boosts up every couple seconds, the CPU_FAN goes to 100%. I have to look again, but if I remember correctly from late last night, my CPU was getting very hot randomly, up to 80 degrees at idle, and almost got to 90+ degrees under load. Something certainly changed that’s causing these higher temps, but I’m not sure where to look for a fix.
when I get home today, I will attempt to reseat all the fan headers and check connections. I also think I may try to reinstall Windows and try to reflash my bios, though I recently installed the most recent version. However I did want to ask here to see if anyone had any different steps I should be trying, or any other things I should try to monitor.
thanks again everyone! I hope I can get this fixed.
specs:
850w psu
3080 ftw3
issue:
