hey guys, just wondering if this was normal for other 5900x owners. a recent build got it no less than 2 months, and ive been reading forums and stuff, seeing people say their gaming temps are at ranges of 75 C while others said they had spikes of 86 while still being able to stay at low 80s. Mine stays consistently at 85 C with not that much spikes (this is on menu, not gameplay). So just wondering if this was abnormal and if it were, what type of things should i be looking out for to make it cooler?
My build is as follows:
5900 X
ROG Crosshair Dark Hero
64gb Corsair rgb rs ram,
Rx 5700xt Gigabyte
8.12 Edit :
I am using an AIO LianLi Galahad 360 mm, i havent really optimised it's fan curves yet. The case is phanteks p500A and the radiator is positioned at the top of the case where its fans are being utilised as exhaust fans. ambient room temps is around like 24-25 C, I'm using an air conditioner in my room, i still feel the heat radiating from the case during gaming. i get like 1-2 % at idle and the temps are 40 - 45 C, mostly at 44 C. It's Windows 10 v 10.019044. The Bios for my motherboard is v3801 which is the latest released 8.12.2021. My PSU is cooler master MWE 750W Gold rated. I havent got other titles installed, just cyberpunk so far. Ive just got Control installed and I;m giving that a go tonight. The rx 5700 xt is gigabyte as requested by JohnBonhamsGhost. The cpu likes to get up to like 84 at around 4.4 Mhz, its voltage is at auto but i see a general constant of 1.35V. You guys can find the picture of my build including its fans orientation below. Thank you so much for the responses guys!
5900 X
Rx 5700xt Gigabyte
8.12 Edit :
