I just picked up a lian li pc 75 case and 4 thermal take smart case fan IIs.
This case is massive and these fans are tiny...
At anything but the lowest setting (1500rpm I think ) the noise is unbearable. But at the lowest setting I can barely feel air being moved inside the case. ive checked my cpu (phenom x4, 9150e) temps with core temp and under load there hovering around 40c. and my gts 250 using riva tuner is around 50c.
my question is, are these fans enough at their lowest setting? I just cant get over the fact that it doesnt feel particularly windy in there.
BTW, nothing is overclocked and i have no intention of doing so.
