Question 9400F + Z390 speed at gaming < 3900
BY66
Commendable
Sep 19, 2019
38
I have newly purchased the Asus Z390 and Intel Core i5-9400F with 2x8GB Corsair Vengeance LPX 3000 MHz.
When I played games like Far Cry 5, Battlefield V and Fortnite, the frequency is only 2970 MHz, is that because I have not updated the BIOS?
I saw everyone is getting 3905 MHz!!
My motherboard is ASUS TUF z390. I use HWMonitor to monitor various devices's data.
I have updated the BIOS and all drivers are updated via ASUS available drivers.
I mainly play BF V, Far Cry 5 and Fortnite. Still they are just doing the stock CPU speed.
But I see many youtube videos about the 9400F are doing 3905 MHz. Am I missing something here?
Is Windows power plan set to high performance? If no the try this.
What is your cpu temperature when gaming? What is your gpu & cpu usages when gaming? What is your full pc spec?
My Spec is:
Asus Tuf Z390
Core i5-9400F
Arctic Freezer 34 eSport Duo
Gtx 1660
2x8GB Dominator 3200
Corsair TX850 850W
Corsair Spec 06 case
CPU running 55~58C usage is around 50%
GPU is high 60~63C usage is nearly 95%
Sorry, it's 1920 x 1080
What v-sync is used for? I never use frame rate limiter
V-Sync helps synchronise your frame rate to the monitors refresh rate to eliminate screen tearing.
Are you running max or near max game settings? Your gpu is running at 95% so it suggests your cpu doesn’t need to run any faster. If you lower the game settings does your FPS and cpu usage go up?
if by everyone you mean yt videos they usually pair cpus with 2080ti at 1080p so the cpu needs to work really hard in order to keep up with gpu.
but if you want make sure that both your cpu and motherboard are ok use cpu z built in stress test to put your cpu under pressure. and monitor clock speeds with HWINFO64 to see if its reaching its advertised speed or not.
All game settings are max'd out. Should I lower the settings to obtain a higher CPU frequency?
I din't know CPU-Z has a built in stress test, I 'll give it a try and report back.
...Is my CPU faulty?
Are we honestly chasing down a missing 30 MHz here under load?
Built in graphics is useless anyway, since you have the 1660....
Sell the 9400F, if you prefer and can; get an 8700K or 9700K, at least....
(Possibly a better cooler will allow your Asus board to run the 9400F at it's max...; you will soon need one for a better CPU anyway)
