[SOLVED] Adapter Help
So the DP to monitor cable is going to monitor #2 - correct?
My general philosophy is to keep things as simple as possible.
For example instead of a GPU port to adapter to cable to monitor path I would opt for a cable that would be direct.
GPU [DP plug] <---- cable ---->[VGA port] Monitor
Just for example purposes.....
https://www.dell.com/en-us/shop/c2g...yport-cable-6-ft/apd/a7717086/tv-home-theater
There may be other suggestions and ideas. I have no problems with that.
Guessing you are trying to connect the card to a monitor with VGA only port. I'd use a DP to VGA. Don't know about that exact brand you picked, the ones we use at work are from Startech, C2G or Belkin, all those we have seem to work fine.
The DVI-D to VGA may not work for all cards.
