Additional Fan Questions?
Thurstenburg
8
The difference according to the stats is that the first link pushes 90CFM at only 19dBA (2000rpm) while the second one which is the sickleflow fan pushes at 69.69CFM at 19dBA. so the first one pushes a little bit more air.
I actually own 2 of these and I have them in my antec 1200, they are quiet in my opinion.
As for the second question, I wouldn't know if to make them intake or exhaust,they will go at the bottom I do not see the point of making them exhaust, but remember that heat rises to the top. Maybe someone else can suggest what works, sorry I do not own the case to know how to best set up the fans.
Ok then. That helps, I was looking at the stats, just seemed bizarre that is all. Thanks for the clarification.
If anybody has some insight as to whether they should be intake or exhaust, would be great. :)
