H hebrooks Distinguished Dec 7, 2009 2 0 18,510 Dec 8, 2009 #1 how do i change to Vista 32-bit instead of 64-bit?
Solution Scotteq Dec 9, 2009 To run Flash content in Vista 64, please use the 32 bit version of your favorite browser and install Flash to that. It works perfectly fine that way.
saint19 Polypheme Mar 20, 2009 15,746 26 60,540 Dec 8, 2009 #2 Your question isn't clear. What do you want?, if is that i think, you can install flash player 32 bits in x64 and isn't problem. Upvote 0 Downvote
M mindxless Distinguished Nov 30, 2009 31 0 18,530 Dec 8, 2009 #3 get a 32bit OS rather a 64 bit Upvote 0 Downvote
Scotteq Splendid Aug 7, 2007 3,958 0 23,460 Dec 9, 2009 Solution #4 To run Flash content in Vista 64, please use the 32 bit version of your favorite browser and install Flash to that. It works perfectly fine that way. Upvote 0 Downvote Solution
H hebrooks Distinguished Dec 7, 2009 2 0 18,510 Dec 16, 2009 #5 Scotteq : To run Flash content in Vista 64, please use the 32 bit version of your favorite browser and install Flash to that. It works perfectly fine that way. Thanks. I tried this and it worked the first time! There seem to be a lot lacking with the 64 bit system - like programs that run in 64 bit! Upvote 0 Downvote
G geowtry Distinguished Apr 19, 2010 2 0 18,510 Apr 19, 2010 #6 saint19 : Your question isn't clear. What do you want?, if is that i think, you can install flash player 32 bits in x64 and isn't problem. First of all never used vista, keep getting yellow bar to down load flash player. my computer is running 64 bit but some websites us 32 bit lost Upvote 0 Downvote
