Question AIO too loud/too weak
Aug 1, 2024
Hello, i've built my pc, specifications below.
The problem is that once i've built it the AIO was too loud, especially the pump - it whined like crazy. I mounted it in front of the case with the pump cables going on top of the radiator because they where too short to mount them at the bottom. Yes - i've made sure that the top of the radiator was higher than the CPU. Then I found out that what I did bad was plugging the radiator fans into pump_fan and the pump into cpu_fan.
So i switched it, and the pump whine lowered down, but as soon as I did that, it looked like AIO lost its cooling power - doing Cinebench 24 at multi-core instantly raised the temperature to throttle (89C) with AIO RPM at 100% (the pump is set to stable 100%). It was better before, because it didn't reach throttle mostly. The last thing i did was remounting the AIO to the top of the case so it would blow hot air out - didn't help.
Btw. it's all happening at negative 35 PBO.
Do you have any idea what could be wrong?
My friend has a lot more quiet and efficient air cooling on the same processor (Fortis 5).
PC:
Ryzen 7 7800x3d
Deepcool LT720
MSI PRO X670-P WIFI
Lexar Ares RGB, DDR5, 32 GB, 6400MHz, CL32
Gainward RTX 4090 Phantom
Samsung .m2 1TB
be quiet! Straight Power 12 1000W
be quiet! Shadow Base 800 DX
Applied paste: Savio Glacier 13.5 W/mK 2g TG-03
Does the noise sound like this?
Ideally you should have the IAO mounted to the top of your case since the pump is located on the CPU's cooling block. Your case will allow the AIO being mounted at the top of the case.
Hello, no the sound is not as bad as the one in the link. It might be normal pump noise but like exagerrated(?) I've already monuted AIO on the top but it didn't help. When i play games, for example Squad, my temps are at 70-75 but the AIO is really loud. And that's on 35 PBO...
A few questions, assuming you still have the PUMP connected to PUMP_FAN and the RAD FANS into CPU_FAN.
1. A noisy PUMP is not common. IF that really is the big noise source, you may have a bad pump. Are you sure that is the big noise?
2. For BOTH of those headers, check in BIOS Setup for the way the MODE is set. That is the item at upper left of the screen for each header with options of PWM, DC, or AUTO. For ALL of your fan headers (assuming they are 4-pin type) this should be set to PWM. and YES, that applies to the PUMP on the PUMP_FAN setting even though its connector has only 3 holes.
3. What does that screen show you for the speed of the pump on the PUMP_FAN header? It should be always about 3100 RPM according to its specs.
4. Go to the screen for the CPU_FAN header where the rad fans are connected. At left centre IF you have a choice, set the Temperature Source to CPU. Below the graph click on Set All Default to set the fan curve above to the default values. What does it show for the fan speed and CPU Temperature?
5. One way you can check for where noise is from IF it is a fan is this. With everything running and with the noise present, go around to each fan and gently stick your finger onto the spinning fan blades to stop it for a moment, then let it go. Any really noisy fan will be obvious from the change.
