Just upgraded my CPU from 2700 to 5800X. Turns out Wraith Prism barely hold the heat of this beast.
Just a plain gaming is (not) fine. It can hold the heat, barely (85'C - 88'C).
The problems are;
1) I usually do more than gaming in one time. And I'm also interested in overclocking the 5800X.
2) I don't want anything big (like Noctua NH D15). I want the cooler to stay compact that it doesn't blocks / hides my RAM slots (MSI X570-A PRO).
3) Keep it air please. I don't want to risk any leakage from liquid cooler.
RGB is meh. I don't care if it doesn't include it (preferably), and won't be bothered if it does.
My budget is around €150 . €170 at max.
Any recommendation will be appreciated thanks :>
UPDATE
3) Preferably air cooler, but AIO liquid cooler is acceptable
You can ignore my case space restriction as I'm going to buy new larger case that could fit anything stuffed inside.
My main goal is to find a cooler that can chill 5800X on it's OC config
Reason for 2# problem: I often need to access the RAM slot directly by hand. So it's a must that the cooler doesn't block or hide / stand above the RAM slot.
UPDATE 2
For anyone who managed their way upon this thread, here's something I found on reddit to help you choosing a cooler for the 5000 series by Robert Hallock (source)
The problems are;
UPDATE
UPDATE 2
