drippyfausett
135
I am kind of in a tight spot. I have started to experiment with video editing (also do moderate gaming right now playing The Witcher) and my x2 3800+ just isn't cutting it for vid editing and I wanted to upgrade my cpu. I'm on a tight budget around $150 usd .
I have Gigabyte GA-MA78G-DS3H 780g chip skt am2+ which on their website supports up to Phenom X4 9750 (no 9850)
cpu cooler I have ocz vendetta
So my dilemma is I found a deal on the Phenom 9600
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103244
at the egg for $135 shipped I was wondering if this is a good deal and a good upgrade or if I should scrap upgrading and just save more money and wait. I do realize that this one has the tlb but at 135 it seems to be a good deal. The next quad would be the 9550 which is $40 more and out of my budget. I also thought about the tri-core but they don't seem to be a good deal to me (or are they). Any recommendations? Thank you for your time
gaiden
85
with video editing in mind those apps do benefit ALOT more from a quad core than a dual core... if 9600 is what you can afford i would go for that.
gl
True.....too bad there is not a 9650BE. Would be a better choice as 1. it is the B3 stepping and 2. it will be able to OC.
If you are really doing a lot of video editing then yea the 9600 is a great deal. But if you game more a faster dual will do you better.
orangegator
1,163
I agree, probably your best choice. Just don't expect to overclock it much.
You could also get a 5000+BE and overclock it to 3.2Ghz pretty easily. It's cheaper and should give a performance boost for all apps, not just those that will fully utilize a quad core.
ainarssems
723
Get the 9850 and enter settings Yourself, it is the same chip as 9750 only higher clocked, if Your board does not support it, it will with bios updates. In the meantime You can set it up manually. Or even better overclock it.
Don't know how long you can hold out but June was the last month that distributors could order 125w Phenom 9750s and 9850s.
95w versions are supposed to be available by Q4.
For $135 the 9600 is a great deal. promo code EMCAHBABH
AMD Phenom 9600 Agena 2.3GHz Socket AM2+ 95W
If your video software (Premiere Pro with MainConcept encoders?) will run 4 parallel threads you will be smokin' fast.
VideoStudio 11.5 Plus uses MainConcept and can be purchased from Amazon for $60
http://www.corel.com/servlet/Satellite/gb/en/Product/1175714229272
drippyfausett
135
So phenoms 95w versions might come out this year. I didn't know. That is very tempting. Some of you say the 5000+ be would be quite an upgrade (especially for gaming) but how much better for encoding? Any ideas
Premiere Pro 2.0
MPEG2 (24 Sec. HDTV 1920 x 1080) to (WMV9 (1920 x 1080))
q6600 = 154 sec
Phenom 9600 = 164 sec
e8400 = 224 sec
X2 5600+ (2.8GHz) = 278 sec
Mainconcept H.264 Encoder
24 sec HDTV 1920x1080 mpeg2 (mpeg2 to H.264)
Phenom 9600 = 65 sec
q6600 = 69 sec
e8400 = 90 sec
X2 5600+ (2.8GHz) = 124 sec
Tom's CPU Charts 2007
http://www.tomshardware.com/charts/cpu-charts-2007/mainconcept-h-264-encoder,380.html?p=1272%2C1275%2C1307%2C1268%2C1267%2C1251%2C1261
jj463rd
1,510
Don't get the 9850.It won't work on your Gigabyte GA-MA78G-DS3H 780g chip skt am2+ board as you have already stated.Even though the Phenom X4 9550 Quad Core is $40 more than your budget it's a great match for your board.
I wouldn't get any defective B2 Phenom X4 CPU like the 9600.
Really go for the 9550.You will be happy with this one.
yipsl
1,666
I wouldn't get the 9600 because you might run in to the errata one of these days. Or you might not. Most people haven't.
What I recommend to you, over a 9600, is the 8650:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103253
By the time you'll see great benefits from the 4th core, it will be time to upgrade, and then you should be able to go Deneb with a bios update.
I have a similar situation. I bought a Gigabyte 780G board and was going to put a 95 watt B3 Phenom in last spring but I couldn't afford DDR2 1066 until after the vacation, so I decided to hold off till spring and get an 8750 and DDR2 1066 all at once.
Here's an old review of the 8750 that includes the 9600 for comparison:
http://www.neoseeker.com/Articles/Hardware/Reviews/amd_phenom_8750/
Here's another review from the same time period:
http://www.overclockersclub.com/reviews/amd_phenom_x3_8750/7.htm
The 8650 for $145 @ 2.3 will be a bit slower, but not by much and it should still equal the 9600 in most cases without fear of the errata.
Mathos
584
The 9600be isn't bad, but kinda like playing roulette when it comes to overclocking. I wouldn't worry too much about the TLB errata, other than making sure the fix is disabled in bios. Anything phenom based will also improve the performance of the IGP since it will be running of HT3.0 instead of 2.0.
With a good video card, and decent 1066 ram, any of the phenom based chips will also be able to game well too.
