Hi, as I mention the speed of my processor is limited to 1.4GHz and never goes up, the voltage I have changed from 0.9V to 1.4V and it does not change.
Everything on the motherboard is by default and when I switch from OS to Ubuntu it doesn't change.
I tried to change it from the BIOS with an overclock, but nothing changes 🙁
Is the CPU temperature normal? Or is it the sensor?
I found something strange in the MSI Command Center application, it detects the clock ratio at 7, but in the BIOS it says 17.5
Thanks
Thanks
