Hi
I just upgraded my system from a Fx-8350.
My current specs are:
Ryzen 5 2600x
Asus rog strix f gaming mobo
G.Skill Flare x 3200 16gb 2x8
Corsair H110i AIO
Zotac gtx 1070 ti amp
Samsung m.2 970 250gb win 10 os
Samsung 860 evo 250gb
2x pny 120gb
Seagate 3tb 7200rpm hdd
Corsair cs or cx 650w semi modular psu
In a Thermaltake F31 Suppressor case.
Now with the formalities out of the way.
I set windows power plan to high performance.
?1) is that setting over riding
Helping or hurting Ryzen Precision Boost.
With those settings I'm seeing in Ryzen master and hwinfo64 that @ idle core clks @4.250ghz but starting cn bench r15 clks go down to 4.016ghz is this normal for ryzen compared to fx cpu's that would turbo up not down.
?2) when trying to manually oc
in bios are there any other settings that needs to be disabled or turned off like when ocing a fx cpu.
I tried level 3oc but reset to default and reset ram because ryzen master was showing the Edc in red something 80-85% of something?.
I have tried finding ryzen oc guides but all videos that i have watched and the 1's i have read don't mention any other settings to disable.
Temps seem fine even though most utilities are reading higher which most are working on to update for 2nd gen ryzen cpu's
Occt and aida64 are very close to ryzen master. Atleast for me.
So far precision boost on
Ram set @3266 i get a cnb score ranging from 1350 to 1394.
3dmark firestrike 17128
Userbench
Ufo across all 3 categories
Ryzen 2600x Avrg user score 92% mine 94.8
Ram avrg user 103%mine 115.
So what I'm seeing i like but just needing some help with settings, fine tuning or good oc basic guidelines.
Thank you for reading and maybe you help.
Ryzen 5 2600x
Corsair H110i AIO
2x pny 120gb
Userbench
