[SOLVED] AMD Ryzen 5900X CPU Power --- Connect 8 pin or 8+4 pin use ?
orodruin
57
6
10,535
Hello to everyone. I'm using an Asus X570 Crosshair VIII motherboard with a Ryzen 9 5900X processor. My power supply is Corsair RM850X.
My question is;
My motherboard has 8 + 4 CPU power inputs. Would I have a problem if I don't plug in the +4 Pin power jack? I don't want to deal with cable mess. Corsair cables are thick and difficult to bend. Can I use it with only 8 pins without any problems?
I do not overclock my processor. Only PBO is active. In Auto setting.
I would be very happy if you give information.
