Question Antec Mercury 240 AIO + Ryzen7, how does it perform?
Jun 24, 2019
13
Hi guys,
I'm planning to buy a Ryzen7 2700 (not X), and I'm planning to get the mentioned maximum boost overclock which is like 4.1 GHz I suppose, will this Antec Mercury 240 AIO be sufficient for it? ( it's not the RGB version)
(I'm on a very tight budget) (please make sure recommending another cooler is the last option, I'd highly appreciate comments from people who's already using or have used this Combo or at least the cooler)
Thank you very much!
No actually. But for Ryzen 2700 i don't think that it will be a problem.( 4790K will do 4.5G Load at ~50C on this one) You're not willing to go more than 4.1G right? Without OC that CPU would work without a problem even with a Air cooler. Tell me your budget i will find something else if you want.. mayby with more Fan Dimensions. NZXT have better radiators.
