antivirus scanners won't help me
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.basics (More info?)
I have tried to scan my system with various antivirus programs, with
absolutely no success.
I don't know what to do next. I even tried to scan in safe mode, couldn't
get onto the internet to try other scannings. used the one I have and screen
just blacked out and computer froze.
any and all suggested welcomed.
forget your worries today, for tomorrow will be a better day.
Is your antivirus software up to date, not only the latest virus definitions
but a version of the software compatible with XP? Have you tried removing
and reinstalling the antivirus software?
Michael Solomon MS-MVP
Windows Shell/User
Backup is a PC User's Best Friend
DTS-L.Org: http://www.dts-l.org/
"deedeelee" <deedeelee@discussions.microsoft.com> wrote in message
news:02D06B40-FCCD-4678-9E4A-D7FF0CEC40C0@microsoft.com...
> screen
yes, I've tried it all. recently I rebooted on debugging mode and McAfee
found a trojan called Korgo. But I'm still having trouble.
> Windows Shell/User
> > screen
If you've tried it all, I can't be much help. Have you contacted McAfee to
help you clear the virus and get your system running again?
If you are sure you are clear of viruses, you should also be sure you are
clear of malware. Download, install and run Ad Aware:
www.lavasoftusa.com.
If you are clear of viruses and malware, you might want to try a repair
install as follows:
NOTE, while a repair install should leave your data files intact, if
something goes wrong during the repair install, you may be forced to start
over and do a clean install of XP. If you don't have your data backed up,
you would lose your data should that eventuality occur.
Assuming your system is set to boot from the CD-ROM drive and you have an
actual XP CD as opposed to a recovery CD, boot with the XP
CD in the drive and perform a repair install as outlined below. If the
system isn't set to boot from the CD or you are not sure, you need to enter
the system's BIOS. When you boot the system, the first screen usually has
instructions that if you wish to enter set press a specific key, when you
see that, do so. Then you will have to navigate to the boot sequence, if
the CD-ROM drive is not first line, set it first in the boot sequence. Save
your settings and exit with the XP CD in the drive. The system will reboot.
When the system boots, a few screens into the process you may see a message
instructing you
to hit any key in order to boot from the CD along with a countdown. When
you see this be sure to
hit a key on the keyboard, if you miss this instruction and the system fails
to boot from the CD, it's too
late, you'll need to reboot and try again.
Once you have pressed a key, setup should begin. You will see a reference
asking if you need to load special drivers and another notice that if you
wish to begin the ASR (Automatic Recovery Console) depress F2. Just let
setup run past all of that. It will continue to load files and drivers.
Then it will bring you to a screen. Eventually, you will come to a screen
with the option to (1) setup Windows or (2) Repair Windows Installation
using the Recovery console. ***The selection you want at this screen is
"Setup Windows,"
NOT "Repair Windows Installation.
The first option, to setup Windows is the one you want and requires you to
press enter. When asked, press F8 to accept the end user agreement. Setup
will then search for previous versions of Windows. Upon finding your
version, it will ask if you wish to Repair your current installation or
install fresh. Press R, that will run a repair installation. From there
on, follow the screens.
Note, in some cases, you won't receive the repair option, only an option to
reinstall. We have discovered that sometimes this is caused by damaged
boot.ini file that can be repaired as follows and also note, in the
instructions, "K" refers to the CD drive in which you have placed the XP CD,
replace that drive letter with the appropriate letter on your system, "K" is
simply an example.
Reboot, this time taking the immediate R option (this is the section I told
you to skip above. In this case, you will need to get to the Recovery
Console to perform the function below), and if the CD letter is say K: give
these commands
COPY K:\i386\ntldr C:
COPY K:\i386\ntdetect.com C:
(two other files needed - just in case)
ATTRIB -H -R -S C:\boot.ini
DEL C:\boot.ini
BootCfg /Rebuild
Once you've completed this function, reboot and see if you can access XP as
sometimes, the problem is the damaged boot.ini. If you still cannot access
XP, then reboot and re-run the repair install instructions at the beginning
of this message.
If you only have a recovery CD, your options are quite limited. You can
either purchase a retail version of XP which will allow you to perform the
above
among other tools and options it has or you can run your system recovery
routine with the Recovery CD which will likely wipe your drive, deleting all
files but will restore your setup to factory fresh condition.
Windows Shell/User
news:C4959427-9DDC-4DBE-B6AF-117191A634E5@microsoft.com...
>> definitions
>> removing
>> Windows Shell/User
>> > couldn't
>> > screen
What do you mean no success? What were your expectations? What are you trying
to do? Do you have some problem?
> screen
